As some of you many know I have lost compression(0 PSI) in one of my cylinders ( #2 ) . The solution I have opted for is to just replace my engine(150,000 miles) with a lower mileage engine(88,000 miles) .
This job is going to surely cost me a fortune so I would like to make sure it is done in the best way possible.
I would like to replace all the stuff that I should while I have both pieces out of the car.
Should I replace the rear main seal while the engine and transmission is out?
Should I replace any gaskets or other parts while while the engine and transmission is out?
Any mounts?
Any suspension components?
Any steering components?
I would like to kill as many birds with one stone as possible.
Thank you all so much! I will try to document this job as much as possible!!!
