If the turbo was doing that, which doesn't happen often, you'd have a huge cloud of smoke behind you every time you drove.
It's possible for the radiator to do this, as it has both ATF and oil next to the coolant. Especially if you have not seemed to lost any antifreeze.
I would do a combustion gas check with the engine running. If you get no results there, do a compression check. This will rule out a head gasket.
If both of those check out, it's a fair bet to assume that your radiator has cracked and the fluids are mixing. Not a good thing, change all fluids as soon as you get a new radiator.
sludge in coolant
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
+1
850man
- Year and Model: 1993 850 GLT
What exactly do you look for in compression readings to rule out a head gasket? I have a 96 850 turbo that lets steam out exhaust after driving 15 in, but conpression is even and 175-180 across all 5 cylinders.
- 4494 Views
Last post by rspi
- 3397 Views
Last post by RickHaleParker
- 2718 Views
- 13 Replies
- 3707 Views
Last post by Atis
- 1159 Views
Last post by nsjames
