I have a oil leak through the oil filler cap. There is a lot of pressure when i undo the cap. Kind of pressure when u release the radiator cap type of pressure. The ABS light came on when driving then a short time later the oil lamp warning light came on. I put oil in (realized it did not need it) and the abs lamp went off. But in a short space (minutes) the oil was spewing out the oil filler cap on a massive way.When I undid the cap it pressure realesed.
Why, what and where is causing the pressurization of the engine causing the oil to spew out??
oil cap pressure leak - 850 se sedan
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Your PCV system is clogged up and needs to be cleaned.
This is the same reason you blew out the cam seal in your other post.
'98 S70 T5
2016 Chevy Cruze Premier
agree on that. While you're at it would be good to order the cap seal chances are yours is hard and crusty from the overspill
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
+1 for the PCV
- Year and Model: Many Volvos
- Been thanked: 75 times
Fix the underlying PCV problem before you replace the cap gasket. At least at this point it is acting as a pressure relief and it might save your RMS.
jamespacheco1
- Year and Model: 850 1994
my 1994 850 non turbo wagon has the same problem...where is the pcv and how do i replace it?
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 6 times
James, you can do a search for fixing the PCV - there's some excellent write-ups here, including photos, and at other Volvo forums. It looks like a lot of fun and hope to do it soon myself!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
polskamafia mjl
Haha...make sure to get the kit from either IPD or FCP.vjaneczko wrote:It looks like a lot of fun and hope to do it soon myself!
Edit: One of the write ups is on the first page of the 850/s/v70 forum.
vjaneczko
Is there any other source?!polskamafia mjl wrote: Haha...make sure to get the kir from either IPD or FCP.
2006 S60R - For ME!
2006 S60R - For ME!
- 2150 Views
Last post by erikv11
- 1152 Views
Last post by Salomons Driveway
