S80 T6 Overheating
RafDaddy 48
- Year and Model:
S80 T6 Overheating
I have a strange occurrence on my 2002 T6 with about 80k miles. It will suddenly overheat usually after it has been run and then parked, restarted and the warning message comes up and the temp gauge is pegged. When I look at the filler bottle the coolant is boiling. First thought is a bad thermostat. The strange part is if I shut it off for a few minutes it will start again and immediately and car will return to normal operating condition and I can drive away. Is there possibly a thermostat relay or do I need to replace the thermostat? If so where are they located? Thanks
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
Does your fan ever kick on? There was a recall for a faulty fan module.
RafDaddy 48
- Year and Model:
Boy do I feel stupid. I know that I should have checked for that but never looked when the engine is running when it was hot. I will check it out and let you know the next time that happens. I appreciate the feedback. If it had a recall would it still be covered?
- 27 Replies
- 8645 Views
Last post by regent
- 1516 Views
Last post by SuperHerman
