Crack in water tank reservoir
1996 - 2004 S40
1996 - 2004 V40
shelly4278
Year and Model: s40 2005
Post by shelly4278 »
I have a major crack in my water tank reservoir. Would that cause my check engine light to go on? Is it a costly repair/
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If the coolant temperature is higher than it should be it could activate the check engine light.
The reservoir is reasonably easy to replace as it is very accessible. Two of our sponsors, MyVolvoPartsOnline and VolvoWholesaleParts.com list the reservoir. Their ads at the top of the forum are links to their sites. You need to know the chassis number as two different reservoirs were used.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
shelly4278
I bought one from the dealership today for about $55.00. Installed it. The tempature is not going up but the check engine ligt is still on??
billofdurham
The fault code will have to be cleared from the memory before the light will go out.
Bill.
Previously:
shelly4278
The car is running fine today. Just clear the code and I should be allset.
