Need 2002 S60 transmission replacement tutorial
lloydmangnallsr
- Year and Model: S60,2002
I would like all the info I need to Replace an automatic trans in a 2002 S60 AWD Turbo.. Procedure for R&R. Model # and if there is an upgrade a better replacement from Volvo.. Thanks! VIN# YV1RH58D022120869
If you are going to take this on yourself, Buy the VADIS (Volvo Service) Software. You can find it on Ebay. To get prepared. The easiest way is to drop everything out the bottom. So be prepared to lift the car up.
