After the car is turned of the fan still runs and it is getting louder.
But the car is not over heating. I looked through the fuses and they are fine as well. What else can I look for?
Fan does not stop running Topic is solved
White850Turbo
- Year and Model:
I have had my fan run after the car is turned off after hard high speed driving. It just runs a bit afterwards to help in the cooling process. It's totally normal. If it runs for more than 5 minutes or so though, you may need a new coolant temp. sensor or a new cooling fan relay.
