looking for best PCV cleaning thread...
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
Does anyone have the definitive webpage, thread or DIY on checking on and cleaning the PCV system?
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1255 times
Post by matthew1 »
PCV cleaning tutorial with photos, by our administrator Justin, with a fantastic addendum by senior forum member cn90.
But -- you knew this was coming -- it's for "P1" cars like 850s and 70s made before 2001. But -- you didn't know this was coming -- the Volvo 5 cylinder cuts accross model lines and is the same engine in your P2 Volvo. Minor differences in hardware and software, but mostly it's the same.
I just bought a P2 car but don't know it well enough yet to comment on just how close Justin's tutorial will match what you need to do for your car. You can do a reconnaissance "quick look" on your engine and compare to his photos to get an idea.
Whatever the case, please get back to us on if this works for your 2001 V70.
Also -> Amazon link
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
The design of the PTC and your intake manifold is going to be a slight bit different from mine, and you've also got an electronic throttle module in the way instead of a regular old throttle body like Matt and I have got.
It would be a great time to clean that.
But, aside from that, it's more or less the same. The system was overhauled to clog a little bit less in 1999, but wasn't totally redesigned until 2004 or somewhere in there.
'98 S70 T5
2016 Chevy Cruze Premier
carboncow
Post by carboncow »
Thanks and great info. I"ll be reviewing the system in the follow week based on your notes. I have noted my ETM has been replaced (yellow label) yet it's starting to show some signs of typical failure again (w/o throwing codes or limp mode, yet).
So maybe I'll have a look at that the ETM while I"m doing the PCV system...
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
