Can someone help please,
I’m trying to locate a correct part, to attach a vacuum pipe. Unfortunately I have now completely failed and need help from someone who knows what’s where
Basically, the pipe I have is attached to the air filter box (outside) I think it’s called a Vacuum Air Pump - Solenoid Valve. The valve itself it’s not big, and it has 2 vacuum hoses attached to it. One on its side and another to the bottom.
If I follow the diagram, most obvious part that resembles what’s on picture is some sort of Air Valve or Pressure Valve at the back of my intake Manifold. Does anyone know, If this unit has a “pin” to attach a pipe to it? I did take a picture of mine when I replaced PCV on my car, but as far as I remember I didn’t see anything on that valve that would remind me to plug the vacuum pipe. Maybe I’m wrong, but please if anyone knows about this issue, let me know.
Vacuum Pipe issue
Vacuum Pipe issue
- Volvo 850 - Air Pump Solenoid Valve
- 6842617 - volvo air pump 2.jpg (48.61 KiB) Viewed 864 times
- inmanb5254fsegr.jpg (81.05 KiB) Viewed 864 times
- 4821 Views
Last post by darrylrobert
- 16 Replies
- 6474 Views
