I hope to get more advice with a new post - Previous post
The main symptom of my 2000 volvo V70 XC at 168000 Miles is the engine cycles from ~200-1000 rpm during idling (frequency at ~ 2 seconds). When I press the gas pedal, the engine can turn faster. The code is P1238: Turbo Control Valve.
If I disconnect the MAF sensor, the engine can run fine (in a limb mode?).
Since I tried one after-market and one Bosch MAF sensor already, I think MAF shouldn't cause this. From another post on the code P1238, I was told this code could also be triggered by Vacuum leakage, or throttle position.
So where is the throttle and how to check if it's functioning?
Also, have anyone replaced vacuum hose and the turbo control valve? How about the turbo control valve from IpdUSA?
Thanks!
P1238 Turbo Control Valve
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
That turbo control valve from IPD is awesome. It livens up the turbo response before 2500 RPM a lot on my car...from what I understand, it helps the XC's a lot too.
Before you replace it, check the vacuum lines first! There are 3 from the valve on the back of the air cleaner box to the turbo charger area. Inspect all of those for cracking, I know mine were pretty far gone.
Your problem sounds more to me like the ETM though, affecting the idle issue.
You can try cleaning it, but you may have to look into a re-built unit. Check out Don's ETM room in the list of forums here and do some reading to see if those sound like your symptoms.
'98 S70 T5
2016 Chevy Cruze Premier
Thanks! But how to go to Don's ETM room? I tried to look under the Volvo Forums, but it isn't listed.
jblackburn
Here you go:
https://www.matthewsvolvosite.com/forums ... m.php?f=12
If you just click the volvo forums link at the top of the page, you will see it in the listing page there.
Since you have a '99, you have an electronic throttle module (ETM) rather than a throttle position sensor on your car. The strange idling up and down can be a symptom of a failing module, or it may just need to be cleaned. But hopefully some things there will explain it a little better for you.
'98 S70 T5
schmidm90
- Year and Model: 2000 V70 XC AWD
Does anyone know where instructions are to replace the TCV? I am probably going to replace the lines this weekend to eliminate my P1238 code. I am also going to the junk yard tomorrow morning to get a "new" MAF, TCV and EVAP valve to eliminate all those possibilities.
My Volvo idles fine, but it stutters around 3500rpm and then will jump up and down 200rpm and then idle fine. I tried to unplug the MAF and it idles the same with/without the MAF plugged in.
2000 V70XC - 199k
1981 VW Vanagon Diesel Westy - 220k
2000 V70XC - 199k
- Has thanked: 2861 times
- Been thanked: 1332 times
It's easy, just pop the new(er) one on and keep all the lines in the same place as the old TCV. The lines are color coded.
schmidm90
Thanks Matt! Do you know any place locally that would sell silicon hose to replace the lines? I know IPD sells it, but that is a few days away and I was hoping to give it a shot this weekend. Thanks again for all the input!
2000 V70XC - 199k
2000 V70XC - 199k
I use Gates 3/16th vacuum line. I get it at my local auto parts store. Make sure you buy vacuum line, they might try to mistakenly sell you fuel line.
schmidm90
Matt, which store is it? Would autozone, CAP or advance autoparts have it? Also is this a hose I might be able to get at a hardware store such as Lowes or Home Depot?
2000 V70XC - 199k
2000 V70XC - 199k
O'Reilleys, but I'd expect to find it or similar brand at any auto parts store. Home improvement stores, anyone's guess.
- 865 Views
Last post by Ncb1331
- 1436 Views
Last post by Pistol Pete H
- 1253 Views
- 1241 Views
Last post by RickHaleParker
- 11 Replies
- 3550 Views
