2007 XC 70 AWD
Is it even possible to read the codes on my car with a OBD II reader? If so how and where is the connector?
How to read codes?
walterschweigert
- Year and Model: 2007 XC 70
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
You can read the generic engine codes with a non Volvo OBDII scanner. The port is located in the driver side foot well, next to the hood release. It will be covered with a black cover labeled OBDII.
walterschweigert
I have an AutoXray 6000 which should work then.
Thanks
Thanks
2007 XC70 AWD 39,000 Mi.
Previous: 1993 850 GLT 135,000 Mi.
JRL
- Year and Model: Several
- Been thanked: 16 times
Many P2s do not have a cover, it's right there staring at you in the face, above and to the right of the hood releaseFCPGroton wrote:You can read the generic engine codes with a non Volvo OBDII scanner. The port is located in the driver side foot well, next to the hood release. It will be covered with a black cover labeled OBDII.
walterschweigert
Found it. It did have a cover. No codes found.
Thanks much.
W
Thanks much.
W
- 12 Replies
- 2385 Views
Last post by kahl
- 1668 Views
Last post by esl_97_850_T5
