Evaporator installation question.
I want to avoid bringing the car to the mechanic. I have fully installed a new evaporator. Now there are the two 'ports' in the engine firewall. They are to mate with the two steel lines (with new o-rings). They don't. There may a slight angle at which the ports exit the firewall that make it hard OR the steel lines are just tight...makes me want to hit it with a hammer to join them. Any hints? They do not slide together like I envisioned them to .
AlanS, That is common especially if you got an aftermarket evaporator. The lines are are aluminum and you can bend them into the proper angle with your hand. It may be a bit harder to do since the evaporator is already installed because not much of the tubing is extending out of the firewall, but it can be done. I would not hit it with a hammer...
you run the risk of deforming the tube end where the new o-rings seal. Just compare the orientation of the tubes on your old evaporator and get your new one close as you can. I had to do that to the one I replaced last fall. Best of luck... oh yea, it is quite a job isn't it! Jay W
- Year and Model: Many Volvos
- Been thanked: 76 times
I had to bend my lines a little bit to get them to line up correctly.
clarkandrew45
- Year and Model: 2008 Volvo S60
Hello there, thanks for this one. I also did some evaporator installation a couple of weeks ago, and this advice is pretty much big help for me. Thanks mate.ajwgator wrote:AlanS, That is common especially if you got an aftermarket evaporator. The lines are are aluminum and you can bend them into the proper angle with your hand. It may be a bit harder to do since the evaporator is already installed because not much of the tubing is extending out of the firewall, but it can be done. I would not hit it with a hammer...you run the risk of deforming the tube end where the new o-rings seal. Just compare the orientation of the tubes on your old evaporator and get your new one close as you can. I had to do that to the one I replaced last fall. Best of luck... oh yea, it is quite a job isn't it! Jay W
- 1621 Views
Last post by lummert
- 1422 Views
Last post by JerryG1970
- 794 Views
Last post by hausmeister
- 15 Replies
- 3734 Views
- 725 Views
