Have not been able to find anything on the minimum or correct fuel pressure for my 99 S80 2.9 on this forum.
Any one know what to expect at say (Key on) and at (idle) ?
Thanks, Uncletom
Fuell pressure
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Have attached/uploaded a couple files from VADIS.
Maybe they have what you need.
99 S80 2point9 Checking fuel and residual pressures.pdf- Checking fuel and residual pressures
- (49.23 KiB) Downloaded 207 times
99 s80 2point9 Fuel pressure gauge.pdf- Attaching fuel pressure gauge
- (43.49 KiB) Downloaded 576 times
Thanks for the reply.
This is all I need to confirm if the fuel system is adequate. My quick test shows to be 40 to 50 KPa,s under the minimum, 48 to 50 lbs. Why the need to use Kilopascal or (KPa) and ask us to convert is a mystery. I have suspected low pressure for quite some time.
Thanks, I have the VADIS CD put away somewhere safe and have not been able to locate it.
99 S80 2.9 / 99 Land Rover disco 1 / 86 Alfa Romeo Spider veloce
- 1171 Views
Last post by Salomons Driveway
- 7036 Views
Last post by adrian22
