Need scratch removal & valour cleaning advice
jackteet
Year and Model: 1996 850
Has thanked: 1 time
Post by jackteet »
Hi Matthew1, May I say how welcome your new topic is. I have a 1998 V70 which has a number of scratches on the paint work.For years I have used "T cut" but clearly I am out of touch with modern scratch removers. The question is which scratch remover product is the best in your opinion. Finally I have velour upholstery which I need to valet. Again, would you please recommend the best thing to use to clean this. Thank you. Regards...Jack.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2662 times
Been thanked: 1256 times
Post by matthew1 »
Hi Jack
I started this forum because I'm also in need of the latest advice concerning paint care, so I'm not the one to help you. I can say I'm trying out a Meguire's scratch removal product. No opinion yet.
Sorry, I'm no help on the velour question.
Also -> Amazon link
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Velour is a sensitive fabric and its cleaning is often best left to professionals. If your upholstery is very soiled or you just don’t want to risk damaging the surface, hire a professional who is experienced with velour.
A word of warning if you do decide to tackle it yourself: Do not clean velour with high heat cleaners, such as steam cleaners. The heat will damage the material and cause discoloration.
Now that I've scared you this is how to do it yourself:
You will need:
A soft brush.
A vacuum cleaner with brush attachment.
A bucket.
Water.
Mild liquid soap, preferably an upholstery soap. When choosing a liquid soap, avoid those with added color. A clear soap is the best option.
Ammonia.
Some muslin fabric.
A suede brush.
Steps to clean the upholstery:
Begin by removing as much dirt as possible by brushing it away.
A vacuum cleaner with a brush attachment can be used to remove loose dust and dirt particles.
Fill a bucket with warm water.
Add a small amount of soap and stir the water. Do not agitate the water to form suds, just mix in the soap gently. Add a few drops of household ammonia for extra cleaning power if needed.
Muslin fabric is a special type of material and is gentle enough to avoid damaging the soft fibres of the velour.
Dip the muslin into the soapy water and wring it out completely. Excess water will not yield good results, so wring it out until it is just slightly damp.
Rub the moistened cloth over the surface of the upholstery using a back and forth motion, not a scrubbing motion.
Repeat as necessary until the surface is clean.
Change the cloth and water regularly so that you are always working with clean materials.
Once the surface is clean allow it to dry completely.
When it is dry brush the surface gently with a suede brush to restore the soft texture.
As with any job of this nature take your time and you will get there.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jackteet
Has thanked: 1 time
Post by jackteet »
Hi bill,
Thank you very much for your very detailed instructions I shall give it a go. Regards....Jack. :D
