Vibration between 135km/h-165 km/h
This topic is in the MVS Volvo Repair Database » S60 Weak Engine Performance
Puruz
Year and Model: C70, 2001
Post by Puruz »
Dear Members,
I have 2001 C70 T5, I am experiencing vibration on steering wheel between 135-165 km/h. If I go faster or slower, vibration does not exist. What may be the problem???
bb4597
Year and Model: xc70 2003
Post by bb4597 »
First thing I'd look at is your tires. I've had problems like this with worn tires ( in 1964, in fact ) and solved it with a new set of "retreads" . Anything to do with wheel alignment, bushings, etc can come into play, I suspect.
Puruz
Post by Puruz »
Actually, my tires are almost brand new. For your information I use two sets of tires. (Winter/Summer), So that my tires in general last long... It is wierd that I only experience this vibrations at certain speeds...
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
do the vibrations come with both set of tires? If it does, then most likely a suspension issue.
If not, have the tire set that vibrates, checked for imperfections, ie bulging, weak spots, etc. I had a tire that looked brand new but was bulging a bit and caused the vibrations. A new tire solved the problem.
Puruz
Post by Puruz »
Actually yes, same used to happen when my wintertires were on....
E170_Driver
Year and Model: bye V70 2.4T, 2001
Post by E170_Driver »
After getting the tires balanced, I replaced the tie rods and drive shafts, which solved the problem on my former 2001 V70.
Good Luck,
Jan
Former 2001 V70 2.4T owner
Puruz
Post by Puruz »
Dear Jan,
Have you been experiencing quite simular problem?? Or all time vibration?
