Crush washer #11998 for Angle Gear, Haldex and Rear Diff
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
The Angle Gear, Haldex and Rear Diff are Volvo part #11998 copper crush washer. This is what Volvo Specialists used for these applications on my V70 R's 90k service.
Buy it from an MVS sponsor and we all win!
This is the same crush washer used in v70xc.com's angle gear fluid flush tutorial for the 1997-2000 Gen 1 AWD cars.
Also -> Amazon link
jadnhm
Year and Model: 2008 XC70
Post by jadnhm »
FWIW when I did this work on my 1998 AWD the documentation I found said to use the same aluminum crush washer that is used for the oil drain plug on the angle gear and rear differential. Also, the crush washers I took off were aluminum, and were exactly the same size as the oil drain crush washers, so I felt comfortable using the aluminum crush washers when putting it back together.
