Removing turbo - pretty straight forward? 1995 855
855 moneypit
Year and Model: 850 1995
Post by 855 moneypit »
Like the topic states. Am I looking at a nightmare or just worry about spilling some coolant and oil?
Thanks ya'll :mrgreen:
850tech
Year and Model: 1995 850 Turbo 5spd
Post by 850tech »
As long as the three nuts to the down pipe, and the 4 nuts that mount the turbo to the manifold come loose, the rest is pretty easy. If they won't break loose you'll need some heat to free them up so you don't break the studs. Also make sure you replace the gaskets and O-Rings for the oil and coolent lines.
j_cd
Year and Model: 1998 S70 GLT
Post by j_cd »
According to this info you can remove the band clamp and separate the turbo without the wastegate. If you have to remove the wastegate he mentions chipping stubborn bolts off with a chisel. There's one nut I cannot get, so I'm going to leave the wastegate in if possible.
http://www.vcoa.org/700-900-faq/EngineT ... eplacement
The oil intake banjo bolt requires a stubby 17mm spanner. Another trip to Sears tomorrow.
This tutorial has been very helpful.
http://www.volvoforums.org.uk/showthread.php?t=48611
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
+1
if you do need to replace the hot side of the turbo, you better PBlaster the hell out of them for a few days. If you do that, they should pop loose without much effort.
If you just need to replace the center of the turbo, then yes, you can undo the oil and coolant lines, intake hoses, and then pop the v-clap and be good to go. I did this to have the center section of my turbo on my 940 rebuilt.
855 moneypit
FCPGroton wrote:+1
Thanks for the replies everyone. Much appreciated. How easy is it to remove the center band? Anything getting in the way ?
j_cd
Post by j_cd »
The bandclamp is simple, just use a pair of pliers to hold the nut at the back while turning the bolt.
j_cd
Post by j_cd »
I've removed all 3 banjo bolts, the coolant and oil lines are loose, but the turbo still won't budge from the wastegate. The coolant banjo bolts have some crust in them, and the oil bolt looks lacquered. The whole inside of the turbo probably has that oil lacquer.
I don't want to break the damn thing. Worst case I'll still be able to replace the water cooling pipes, hoses, bolts and washers. I'm glad I haven't bought the rebuild kit yet, I don't know if this thing is coming out. I'll try tapping it with a mallet or something, I don't know man.
You'll need to access the front facing coolant banjo bolt from below.
j_cd
Post by j_cd »
I put some gloves on and pulled on the turbo a bit. It came loose pretty easily. Now it's time to order the rebuild kit, and maybe the oil supply line too.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
Noob question: Do you have to drain the oil and coolant if you're pulling out the turbo?
1997 855 GLT - R.I.P.
2006 S60R - For ME!
db130
Year and Model: 2002 V70 T5
Post by db130 »
coolant - yes, quite a bit will come out so draining it beforehand would mess things much neater
oil - no, i found the oil loss from the oil lines to be minimal upon removal from turbo, you could probably even stuff a rag into the banjo bolt to minimize oil loss
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
