2004 S60 repeated low beam failure
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
98expeditionXLT
Post by 98expeditionXLT »
I replaced the H7 low beam bulb on the drivers side about two months ago. Now it is out again. I did not touch the glass of the bulb during installation, however the connector block is broken and I had to plug one connector in by itself. The other connectors were still in the block. Is this just a random defective bulb or is there some other problem I should be looking at?
jjaV70T
Year and Model: V70 2.4T 2003
Post by jjaV70T »
Hey!..I have a 2003 V70 and replaced the lamps 2 x, If you have a volt meter check the connectors for amount. FCP has them for $9.00? one here so.cal..$16.00, stock up. BEST!,
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
98expeditionXLT
What voltage should I have at the connector?
priapism
Year and Model: 01 S60
Post by priapism »
My connector block is broken too, I wonder if that will have any affect on it?
Titan LE : S60 2.4t : 91 325i : Spec E30 #33
Checksix
Year and Model: V70 T5 2001
Been thanked: 2 times
Post by Checksix »
My connector block turned to dust some time ago, and I just hook the brass connectors seperatly to the bulb. It hasn't seemed to make any difference. My bulbs generally last about 18 months, one was 12 months. This seems short to me, but it has been sonsistant. I run Silver Stars.
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
98expeditionXLT
I installed a new bulb and hopefully it was just a defective bulb.
