Exhaust problem- 850 se Sedan
poroman
Year and Model: 850 SE 1995
Post by poroman »
I have a exhaust sounding leak comming from the system. It sounds like its comming near the front half. I think it might be the exhaust manifold gasket or the front flange. Is there a way to identify the problem??
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
Well, you can get a longer piece of rubber tubing, like vacuum tube, and run one end to your ear, and probe around with the other, but be careful. You should hear the sound get louder when you get close to the leak. Use caution not to get anything tangled up in moving parts.
You'll have to have the engine running while doing this, so have a safe partner. Use it like a stethoscope.
Good luck.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Dump soapy water on it and watch for bubbles. Or put it up on ramps and hold the back of your hand to it and feel for warm air. I suspected the same places on were leaking, only I couldn't find anything. I tightened up any and all bolts I could reach - at the exhaust manifold and turbocharger on mine, and the smell I had been getting seems to have gone away.
'98 S70 T5
2016 Chevy Cruze Premier
