Hi all,
I bought a used 2002 Volvo S60 last November. It's run pretty well until last week when it wouldn't start.
I finally got the starting problem fixed (the red/green wire slipped off it's spade lug) but now my wipers don't work. I manually removed and inspected every fuse in the block and all are fine.
I suspect a relay, but have no documentation to help me troubleshoot. Doing a search here shows some diagrams for an S90 but I need one for my S60.
If a diagram isn't available, can someone at least tell me what the relays in [FST1, FST2, FST3, FMA1, FMA2, FMA3] are for?
Is there ANY documentation on what each location controls?
Thank you,
~Rick
2002 S60 fuse/relay diagram?
The red/green wire connects to the starter solenoid. It's a rather poor design, IMHO, to use a spade lug for this connection. Why not use a screw or more secure method given the generally high-quality engineering Volvo has used elsewhere?
- 6129 Views
Last post by jonesg
- 2095 Views
Last post by legalstuff
