check ending light Topic is solved
bpeesy
check ending light
Post by bpeesy »
I have a 1997 850, the check engine light came on & using a diag tool, I'm coming up wth code p0755 shift Solenoid b malfunction. Question: does anyone know that that is? I am mechanical and will repair the car myself, if only I knew what that was & how to go about replacing/repairing it. Help !
Jot
Year and Model: C30 2010
Post by Jot »
If you missed putting the car in gear that is when you shifted the handle was located between two detents a code can be thrown. If you have a code reader reset and see if it returns.
