fuel door will not open!
teri from wyoming
Post by teri from wyoming »
I can not get the fuel door to my 1995 850 turbo wagon open. Help!
Guest
Post by Guest »
Alright, here's how to do it. First, open your trunk, and then that small storage box. Then, feel along the right side of the storage device, until you can get a hold of the actual right side trunk paneling. Pull it off. Then you should see on the right side of the car, directly behind the outside ligts a felt tab with a knob at the bottom. Take that off and there should be a little string. Pull it back. Then put everything back together.
