Smoke from engine
steve1000
Smoke from engine
Post by steve1000 »
What would cause exhaust smoke to come out of the oil filler cap, a little from the exhaust system but mainly it seems to get inside the car as I can smell it through the heater vents.
thanks
steve
prienzo
Year and Model: S60R, 2007
Post by prienzo »
This same problem happened to my friend. He never found out what it was, but I do have a warning. A mechanic told him to drill holes in the oil cap and it would solve the problem. He was driving a few days after this when his car lit on fire. Whatever you do, don't take off the cap or drill holes into it. It may seem logical, but like I said, a mechanic told him to do it.
dosbricks
Been thanked: 2 times
Post by dosbricks »
This sounds like a plugged up PCV system. Oil sludge can clog up the hose that goes from the collection box under the manifold over to the flame trap on the throttle body. The result is combustion gases building up pressure in the crankcase.
It would help on a question like this, as it would on most, to know the model, year, and mileage.
turbotim2
Post by turbotim2 »
I agree with dosbricks, if the PCV system is fine after checking it over then more then likely you are getting blow-by on one or more of the pistons.
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
steve1000
Post by steve1000 »
I think the suggestion of drilling holes in the oil filler cap sounds a bit unscientific and obviously dangerous.
Will check out the PCV hoses, hope its that and not piston blow-
by as would that suggest new rings or even a rebore?
Car is a 1998 2.5Turbo with only 76000 miles.
thanks
