atf level check Topic is solved
volvo c70 fanatic
atf level check
hello everybody, i'm the proud owner of a c70 t5. but i don't know how i can check the level of the transmission fluid. i have found the yellow level stick but i want to know if the car should be running and if it should be in Drive or Neutral. thanx
- Has thanked: 2660 times
- Been thanked: 1254 times
Neutral, warm, level surface.
White850Turbo
- Year and Model:
And with the car runningmatthew1 wrote:Neutral, warm, level surface.
