Hey guys,
I've been trying to diagnose the problem for a couple of weeks now. I have a pretty bad loss of power when driving my '98 S70 base model. Putting it in 4th gear or even 3rd up a hill going 50 mph I still lose speed when I floor it. I got the codes out and I changed the O2 sensor, the distributor cap and rotor, and the fuel filter. I've also changed the spark plugs and used the spray water test to check for faulty spark plug wires to see if there was any arching. I'm still getting the D03xx codes for misfiring in a few cylinders and also the code for random misfires. What could be causing the issue? I've yet to check for vacuum leaks, but I am going to. Could it be the ignition coil? Would it cause such severe misfires? Another thing I was thinking about was the timing. Could the timing belt be off and cause all the misfires? I'm stumped!
Anthony
1998 Volvo S70 Misfiring--Tried Many Things
PCV cleaning & replacement
. I know that a shop that was trying to diagnose my car did that water check thing. A week later it was still running rough. I pulled off the spark plug boots and found water in there. It stopped misfiring after I dried it off.
1998 volvo v70 non-turbo 140,000
I go to the junkyard to practice future repairs.
- Year and Model: Many Volvos
- Been thanked: 76 times
I bought the same wires and had nothing but trouble. Once I put the Bougicord wires on I have had no problems since.I bought some Bosch from Amazon, life time warrantied ...
Bosch is great for the cap and rotor and I have had good luck with the cheap Bosch copper core plugs but my '94 hated the Bosch wires.
My 2c,
mikennedy12
- Year and Model: 1998 S70
Try the mass airflow sensor. I had a similar problem. Changed the plugs, wires, and O2 sensor . Mass airflow sensor fixed it!
- 13 Replies
- 5068 Views
Last post by SuperHerman
- 1855 Views
Last post by precopster
- 22 Replies
- 1993 Views
- 33 Replies
- 7452 Views
Last post by styoung94
- 926 Views
Last post by hypo
