My car has slowly been getting louder over the last couple weeks. Tonight I jacked the side up with the car running, and took a look underneath (properly supported first, of course). The leak appears to be at the clamp around the ball joint between the front and rear portions of the exhaust system. I've done a quick search, and didn't see any other reports of this issue.
As the pipe in front and behind that joint appear to be fine, but the clamp at the ball joint is quite corroded. It might need some heat to come apart. I'm wondering if others have had a similar failure, and what repair options others have pursued. What material is the stock exhaust system? I'm tempted to cut the ball joint section off with an angle grinder and cut-off blade, and slip a sleeve overtop to be clamped or welded in place. I'm thinking the ball device is only to assist in alignment during assembly on the vehicle, and doesn't actually offer movement at this joint once tightened?
Exhaust Leak: At ball joint
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
I saw that clamp on FCP when checking out exhaust parts this aft. My clamp is still tight on the pipe, and the leak feels like it's coming from the top, so I suspect the pipe is cracked or corroded at the clamp. I guess the next step is to pull it apart and take a closer look at what's failed.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
db130
- Year and Model: 2002 V70 T5
my s70 went through the exact same problem as your car this spring-summer(progressively louder exhaust) until the tailpipe broke right after the slip joint, with clamp still holding onto the catalytic converter. what you suggested would be perfectly acceptable if you can find the proper piping that is the correct diamter. i went overboard with the repair and replaced the entire exhaust system with IPD's 3" turboback exhaust. the rest of the old exhaust was in good condition w/ the exception of the slip joint and the rolled edge of the exhaust tip looking ratty. my guess is the material of the stock exhaust would be t409 stainless(judging by the surface rust buildup).
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
- Been thanked: 504 times
Known point of failure.
Forget about the clamp thingy.
Go to a Muffler shop and ask them to weld using a sleeve.
They did that for me in June 2008, so far so good.
It cost me $60 in June 2008.
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I agree with the sleeve solution. Meinke muffler shop fixed mine for $25.00 last month. The shop had the right diameter pipe for the sleeve. I didn't want it welded for fear of burn-through, so they just zipped on two U-clamps. It seems tight.
HOWEVER, in the process of cutting off the ball part upstream from the muffler pipe, the cat & pipe got moved around a lot and left me with a leaking exhaust manifold gasket (the old one was pretty crispy anyway). The new "donut" gasket I installed still leaks a bit, not sure why. Maybe the butt surface of the ex. manifold wasn't cleaned well enough. So I need to do that again. Volvo likes to get $52.00 for those gaskets; I think I got mine from FCP for $9.00. You'll need two 4" x 5/16" stove bolts and a torch or dremel to cut the old bolts off. If you're under the car when you cut off those ex. manifold bolts, watch out they're spring loaded and those springs really take off when set free.
Good luck.
Good luck.
renns
Thanks for the hints guys. I'll give the sleeve repair a go. If it's pretty straight-forward, I'll snap a few pics and post them here.
- Year and Model: Many Volvos
- Been thanked: 76 times
The only down side to welding it up is that you set yourself up for a manifold back replacement if the muffler goes bad. My son's 850 had been welded and it greatly complicated changing his cracked exhaust manifold.
renns
Good point, Lee. If the car lasts that long, I suppose I could always roll out the welder again, and cut and weld the new muffler in place.
renns
Repair completed - no welding required. The ball joint section was cut out with an angle grinder and cut-off wheel, leaving a gap of about 2" between the front and rear pipe. A 1-3/4"ID x 6" long piece of exhaust tubing was slid in place to join the two free ends. Std exhaust U-clamps were used to secure the repair section. The 850 is quiet once again!
The ball joint section had rusted to the point of cracking, which was the source of the leak. The pipe was in decent shape ahead and behind that ball joint, so I expect the repair should last a good while.
- 11 Replies
- 3168 Views
Last post by theWIFES_S70
- 82 Views
Last post by DennisCA
- 599 Views
- 1569 Views
Last post by kahl
- 1597 Views
Last post by jimmy57
