95' 850 pvc is done but I still have white smoke??
I have cleaned my new pvc twice over the weekend and I still have white white smoke coming from the dip stick. I don't know why any ideas would be great.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Probably worn valve stem seals at this point, then. Exhaust gases escape past the worn seals and are more than the PCV system can handle, even if it is clean.
Do you get a puff of blue smoke out the exhaust after idling for a while, or on first start-up?
A bit of a heated debate on THAT issue:
http://volvospeed.com/vs_forum/index.ph ... e-periods/
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
It's a biggie - but it could be done in a weekend.
'98 S70 T5
Could also be worn rings, basically anything that allows excessive cumbustion gases to leak into the crankcase. There is only so much pressure the PCV system can handle before it's overpowered.
One question though, when you did the PCV, did you clear the holes in the block for the breather box? If they're clogged she won't breath at all.
The top hole never seemed blocked in the first place. The lower was the problem the first time I did and that's what I thought the problem was this past weekend I cleaned it not much there, pulled it apart again and cleaned it a third time then asked.
Can I get a write up of the valve stem job I may have in the future?
Oh and no blue smoke out the tail as far as I can tell.
