2003 v70 making a whining sound from engine
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
v70 dude
Year and Model: 2003 v70
Post by v70 dude »
Another perplexing issue has arose from my good ol' V70. Let say I run it up to 1500rpm (in park), now I never let up off the pedal, I just hold it at that one spot. The RPM goes up then after a second or two it will drop down 500 or more. What ever the problem is, I feel it is the reason for the high pitched whining sound from the engine, and it sounds like it is near the alternator. I'm still having a problem with the car dying on me when I make a left turn (most of the time its a left turn). Brake stop working as well as the steering but, she fires right back up and I'm off.
tigmaned
Year and Model: blacked-out V70 04
Post by tigmaned »
always hard to say without being right there to hear or look at it! but did you check the easy stuff like a bad vac line or one that fell of a contector? no check engine light on??
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
has the throttle body ever been cleaned? If not, start there.
Retired MVS Contributor
Post by Retired MVS Contributor »
jda2000 wrote:has the throttle body ever been cleaned? If not, start there.
This may or may not be the problem, but it is easy to check...While the engine is running and the noise is present, remove the dipstick...If the noise stops, you have a breather box problem...I don't know what makes the noise but have heard that there is a bladder in the breather box that causes this...It results in positive crankcase pressure instead of negative and as a result oil starts to collect in the breather box...A PVC overhaul seems to be the answer...
v70 dude
Post by v70 dude »
Thanks guys, I will do all of those, or at the very least check. I hope that cleaning the throttle body isn't a problem. I guess that would be a garage issue or dealer.
