I have been flushing my ATF (Yes, disconnect the cooler hose and flush ATF) using the following guidelines:
- Mobil Synthetic ATF (It take about 9-10 qts for a flush).
- Every 20K miles.
Is this too excessive and not needed?
Just curious How often do you guys flush your ATF?
How Often Should You Flush Your Transmission Fluid?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I do a drain + fill (after having done 4 in rather quick succession) every other oil change or so.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
I do this every third oil change.ecbsykes wrote:I do a drain + fill (after having done 4 in rather quick succession) every other oil change or so.
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I've been disconnecting the transmission radiator hose, pumping out the old and putting in the new about every two years. It takes about 12 qts of DexMerc III. It seems like good insurance against transmission failure ('97 855 GLT w/ 140K miles)
JRL
- Year and Model: Several
- Been thanked: 16 times
Drain and fill every other to every 3rd oil change
Naturally the first time is a flush, depending on the condition and mileage.
I do not flush an (unknown) trans with over 60-70K miles
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I change every 30K with the Mobil fluid (about a year for me). After about 20, the Dex-III fluid in my T5 was brown again, which is one of the reasons why I switched.
You have an NA, which are nowhere near as rough on the fluids, so you could probably stretch that interval out to 40K.
'98 S70 T5
2016 Chevy Cruze Premier
C@lvin
- Year and Model:
- Been thanked: 2 times
I just did a drain in fill in my 2000 V70 using Mobil Synthetic. It had a new tranny replaced by the dealer for the PO approximately 60K ago. The fluid was still slightly red and smelled good. Prior to this I had not done anything with the fluid, but plan to do regular drain and fills now.
I use Valvoline High Mileage DexIII/Mercon when doing a drain and fill in my 98 (4 speed auto).
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
jblackburn
Probably so.thecheat wrote:Should I do it on a 96 with 135000, good looking and smelling fluid, with no apparent problems, and probably no prior service to the transmission?
I would go with what the above guys said, though...a drain-and-fill a little bit at a time. Drop the contents of the pan and replace that amount, then wait a few weeks and do it again.
'98 S70 T5
- 11 Replies
- 2732 Views
Last post by oragex
- 11 Replies
- 1202 Views
Last post by MoVolvos
- 1577 Views
Last post by Turbo_Boss
- 24 Replies
- 4164 Views
Last post by bigbrain
- 31 Replies
- 5551 Views
Last post by VolvoOwl98
