1999 V70XC rear cam seal leaking
I've got a 99V70 XC with the rear cam seal is leaking. I dont have cam sensor where most would leak. From what I can tell the cam needs to be removed.Anyone got a link or instructions on doing this? Thanks.
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Rear as in the one hiding behind the turbo pipe/cam sensor? The sensor is the only thing that needs to be removed.
https://www.matthewsvolvosite.com/forums ... =1&t=24925
'98 S70 T5
2016 Chevy Cruze Premier
There is no cam sensor.There is just a blank cover.I thought just pull the cam sensor.FCP sent me the seals,but no cam sensor.
1999 V70 XC
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
jblackburn
Hmm...another strange difference in the 99's, huh? I no longer have my computer with VADIS with me at work, but I can take a look for you when I get home.
'98 S70 T5
Its just a blank cover,and no way to remove it from what I can tell. My other 99 has a 2000 setup from the factory.I went to change the 02 sensor and the 99 will not work.Different plug.Called Bosch,and they said that late in 99 production they swithched some models into the 2000 setup.
1999 V70 XC
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
- Year and Model: Many Volvos
- Been thanked: 75 times
They are rare in North America but you may have a Fenix ECU system.
So any idea on the fix? Whats different on this motor or vehicle all together? I know on the trim package, I've never seen one like this.
1999 V70 XC
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
jblackburn
This is what VADIS has to say about it (look at the lower part of the file for the rear one).
camseal99.pdf- (840.29 KiB) Downloaded 688 times
'98 S70 T5
Olivettibakebean
- Year and Model: XC70 1999
Thanks Jblackburn, I'm an owner of a rare 99 can this is just what I'm looking for!jblackburn wrote:This is what VADIS has to say about it (look at the lower part of the file for the rear one).
- 22 Replies
- 9589 Views
Last post by ggleavitt
- 1301 Views
Last post by iRenaissanceMan
