J Hose Leak
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Esnoyer
Year and Model: V70 03
J Hose Leak
Post by Esnoyer »
I have had an ongoing problem with my Check Engine light coming on from time to time,I had a new volvo gas cap installed
after avolvo dealers computer showed a valcum leak.eack time the light comes on it still showes a valcum leak...
Dealer did a smoke test and NOW says its the J hose and in order to replace it the exaust system must be lowered,a pan
as well ,all of this to replace a $0.25 hose ,Oh yes plus hose clamps..THEY only want $329.00.. Great VOLVO design..
Has anyone replaced this hose ,any ideas??
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Only one problem, an 01 does not use/have a J hose!
jbrown122
Year and Model: 1999 V70, 1995 850
Post by jbrown122 »
Are you sure the 01 doesn't use a J-hose? Ipd sells one for the 01....
Anyways, here is a link to a video explaining where the J hose is on an older model, ( but I believe it's still in the same place. It helps to remove the fuel filter, you will have more access to the hose. A local dealer wanted to charge me $380 for this job. Got it from ipd for $20...
JRL
Post by JRL »
As I said, I didn't THINK a P2 used a J hose, however if yours has one, an S70 is about a 15+ minute job to change it over...and I can't believe a P2 is a 2-3 hour job!!!
I will be chatting with my mechanic tonight so if you can hold off (and if I remember to ask him), I'll let you know the skinny
Esnoyer
Post by Esnoyer »
My car is a 03 V70 the hose is in a location that would only allow for a childs hand to get into,maybe a set of tongs or long needle nose pliers?? I checked out Utube, wish mine was that easy.
