I HAVE NO MANUAL FOR MY 95 850 GLT NON TURBO. CAN ANYONE TELL ME THE ENGINE OIL TO USE AS FAR AS WEIGHT. FURTHER, THE RECOMMENDED POWER STEERING FLUID GRADE OR CERTIFICATION WOULD HELP.
ALSO CRANKCASE CAP. W/ FILTER
THANKS.
OIL RECOMMENDATIONS?
White850Turbo
- Year and Model:
Depending on your climate, you can typically run 5w-30 or 10w-30 in these cars. If you get valvetrain noise w/ the 30 weight oil for some reason, it's perfectly safe to jump up to 40. I wouldn't go any higher than that though. Also, running synthetic oil is extremely important for engine longevity. It has also been determined that the OEM oil filter is the best. In an N/A car, it'd be good to change the oil every 5k miles. As far as PS fluid goes, I got mine from the dealer. It's green and is supposed to be good for anti-foam properties.
- 3758 Views
Last post by precopster
- 20 Replies
- 4697 Views
Last post by vtl
