Windshield washer not working on 2004 S80
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Dennis G
Year and Model: S 80, 2004
Post by Dennis G »
My windshield washer on my 2004 S80 does not work. It is full of fluid and the fuse under the hood is good. There is no sound when activating. Can you please explain how I might check this, or replace the pump, if that is what is wrong? I am no mechanic but I can take off and replace. Where is this pump located and what is the best way to remove?
Thanks
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
VADIS instructions are attached. Note: Where it says "Remove the fuel filler pipe" I believe it should say "Remove the washer filler pipe".
S80 washer reservoir.pdf
(72.08 KiB) Downloaded 1958 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
