Hello,
The return line on my 2000 S70's power steering has sprung a leak. I don not have the time right now to replace the entire line, I was wondering if the stop gap fix I had in mind would work: Cut out the rotten piece and replace it with the appropriate sized rubber high pressure line.
Pieter
Power steering leak...will this quick fix work?
Pirate99gs
- Year and Model: 2006 V70AWD
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Probably not unless you can get a crimp around both ends of it. Most places would ask you to remove the line to do that, however.
For the time being, a tight clamp (might) work, but it will still probably leak some.
'98 S70 T5
2016 Chevy Cruze Premier
- 717 Views
Last post by wizechatmgr
- 30 Replies
- 24544 Views
