Small cut on inner CV boot
takane2
Year and Model: 850, 1997
Post by takane2 »
The inner CV boot on one of my new axles has a little cut in it. I was wondering if anyone has tried to do anything similar to patching a hole in a inner tube on a CV boot? Since the slit is so tiny, less than a centimeter long there wouldn't be any substantial loss of grease or contamination. I don't really see a need to take the whole axle off to replace and repack the boot.
pablotar
Year and Model: v70 1998
Post by pablotar »
I could be wrong, but I would imagine that if you patch it, you'd need to patch on the opposite side to balance it, as the patch itself might be enough to throw things off once you get the car going fast enough.
1998 volvo v70 non-turbo 140,000
I go to the junkyard to practice future repairs.
JDS60R
Been thanked: 3 times
Post by JDS60R »
Replace boot.
Centrifugal/centripetal force will sling the grease out any hole. Temp change and daily heat/cool cycle will draw moisture in and create rust/wear
Retired
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
+1 = Just replace it now and be done with it.
A CV boot is a miraculous thing, as long as it's whole!
You've got a slit? You've got a hosed boot...Sorry. :(
takane2
Post by takane2 »
Oh well, I suspected as much. It will be one of the first things on my todo list once I am un-unemployed :roll:
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Temp fix: You could probably roughen the area with sandpaper and then go several coatings of superglue or epoxy.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
BEJinFbk
Post by BEJinFbk »
ecbsykes wrote:Temp fix: You could probably roughen the area with sandpaper and then go several coatings of superglue or epoxy.
IMHO, I don't think that would even start to work.
Finding an adhesive that would even bond to a boot
would be pretty impressive, and that adhesive would
also need to be very flexible. Sometimes broke is just broke...
Red-Arrow
Year and Model: 850 T5 1995
Been thanked: 2 times
Post by Red-Arrow »
There are band aid fixes but nothing better than a new boot. The hardest part of this job is opening the hub nut. You need like a 5 foot bar and some will power to bounce on it. The CV clip can also be a pain as well as removing the ball joint. I would replace it personally even though its a horrible job. I noticed that the CV boot on the driver side looks like its perishing. I will probably have to do the same thing as you sooner rather than later. Yes I'm out of a job as well ;-)
Life would be enjoyable if it wasn't so painful to live.
Year and Model: 2004 V70 2.5T
Been thanked: 468 times
Post by cn90 »
I wrote a DIY here, HTH. You may as well do both sides while you are there.
About $30 per set of boot for EACH side. Follow this instruction!
Axle CV Boots Replace Tips/Tricks
takane2
Post by takane2 »
I will inspect the other boots but they shouldn't need replacing, this is a brand new EMPI installed less than a month ago!
