pulsating idle
cstmcool
Year and Model: 1997
pulsating idle
Post by cstmcool »
gotta 97 850 non-turbo that has blown three return fuel lines right between the fuel rail and pressure regulator in about a month after i repaced the line the last time i have been getting a pulsing at idle when i rev upthe rpm's it goes away.Need some help i have changed the mass air flow sensor and still got the same pulsing :?
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
check your fuel press and see exactly what its doing. It sounds like when its idleing its building up the fuel press. to high and when you rev the engine its able to get rid of the extra fuel/press..
If its blowing the return hoses you could have a bad fuel pressure regulator or a blockage from the return line back to the tank. I would say bad FPR though.
1996 Platinum Edition
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Agreed.
'98 S70 T5
2016 Chevy Cruze Premier
