I have been experiencing an increasing delay for the cabin electronics to be enabled when I start the car.
The actual time varies, but it is usually several minutes before the climate control, radio, windows or seats are enabled. If I am not screaming, I can hear the relay eventually click, and then all is well? During this time, the cluster items (temp, fuel, etc.) all register normally.
The code scan is clean. Winter is fast approaching and I am not looking forward to sitting in a cold car waiting for the blower to come on for several minutes.
help
delay after start-up
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Next time it happens, twitch your ignition key. I'm betting you have a bad electrical portion of your ignition switch - mine used to do the same thing.
'98 S70 T5
2016 Chevy Cruze Premier
wurkin4it
- Year and Model: 240, 1989
I replaced the ignition switch yesterday. It didn't fix the problem. I neglected to post that the SRS light will remain on while I am waiting for this delay to pass. It eventually goes out, then the system will energize everything. I had someone suggest the driver door latch. I have no effect on the problem if I cycle the door lock.
Again, I thank you all for any and all help with this.
wurkin4it
Michigan - Retired
89 240DL
00 V70 GLT
Michigan - Retired
89 240DL
00 V70 GLT
Who is online
Users browsing this forum: Ahrefs [Bot], AwfulAccuracy, Google [Bot] and 25 guests
