s70 hood won't open ?? Topic is solved
Guest
Post by Guest »
After pulling the hood latch lever inside my car the right side of the hood pops up a little but the left side remains down. Using the under hood latch does not release it. Any ideas on how to open hood or fix problem?
1998 s70
dosbricks
Been thanked: 2 times
Post by dosbricks »
https://www.matthewsvolvosite.com/chat/p ... t=s70+hood
This thread will answer your question. It's a simple fix.
Open the hood by going back and pulling the inside hood latch a second time after you applied slight lift.
Jot
Year and Model: C30 2010
Post by Jot »
Tree ten mm bolts need to be loosened on the stuck latch then push the mechanism down about 1/8" and retighten the bolts
