TURN SIGNALS
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
GUEST
TURN SIGNALS
Post by GUEST »
I NEED HELP FIGURING OUT WHY MY TURN SIGNALS DONT WORK AND ALSO THE MESSAGE CENTER DONT WORK...ACTUALLY ANYTHING ON THAT ARM ONLY,, DOES NOT WORK...I CHECKED ALL FUSES AND THEY WERE ALL GOOD...DOES ANYONE NO WHAT THIS COULD BE...[/b]
Visiting
Post by Visiting »
[quote="GUEST"] I NEED HELP FIGURING OUT WHY MY TURN SIGNALS DONT WORK AND ALSO THE MESSAGE CENTER DONT WORK...ACTUALLY ANYTHING ON THAT ARM ONLY,, DOES NOT WORK...I CHECKED ALL FUSES AND THEY WERE ALL GOOD...DOES ANYONE NO WHAT THIS COULD BE...[/b][/quote
Any Help here I just had the eact same thing happen on my S80 yesterday and cannot seem to find out what is wrong. Let me know if someone has some ideas.
Tongster
Post by Tongster »
Visiting wrote:
GUEST wrote: I NEED HELP FIGURING OUT WHY MY TURN SIGNALS DONT WORK AND ALSO THE MESSAGE CENTER DONT WORK...ACTUALLY ANYTHING ON THAT ARM ONLY,, DOES NOT WORK...I CHECKED ALL FUSES AND THEY WERE ALL GOOD...DOES ANYONE NO WHAT THIS COULD BE...[/b][/quote
Same thing happened on my S90. None of the signals work, plus, the lights on the passenger side are brighter. Hazard doesn't work as well.
Someone must know how to fix this...help us!!!
Guest
Post by Guest »
The problem can be fixed by resetting the power to the steering column module. Do this by pulling the fuse to this module. Just like rebotting a computer.
guest
Post by guest »
Where is the fuse for the steering column module?
Volvo Pro
Post by Volvo Pro »
We had the problem of the signal light staying on and not working. I finally found a site that helped. It is as simple as changing the bulb in the front of the car. The bottom of the bulb gets melted together and stops working. We paid less than $3.00 for the bulbs at Wal-Mart and only had to replace the one on the side that stayed on. I'm sure that eventually we'll have to change the other but the bulbs came two in a package. Your owners manual will tell you how to replace the bulb and what kind. But you can look it up at Wal-Mart if you don't have your book.
Guest
Post by Guest »
yep. pull the fuse for the turn signal indicator and the steering wheel controls (21 & 22). Reseed them. It's like rebooting a computer. It worked for me! find fuses between the dashboard and the driver's side door.
Lee Smith
Post by Lee Smith »
updated the software for the steering column
guest
Post by guest »
hi can anybody help my 95 850t5 the indicators only work now and then but the hazzords work fine ?any body had this sought off problom thanks jon
