tailgate lock will not disengage?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
chairexpert
Year and Model: V70 2006
Post by chairexpert »
Hi,
I have a 2006 V70 and the tailgate opens sometimes, and sometimes it doesn't. As of late, it has not opened at all. I disassembled the tailgate cover and the latch seems to be working okay, but the lock will not disengage? Suggestions Please.
thank you,
Gabe
Dallas,TX
wedcarter
Year and Model: XC70 2005
Post by wedcarter »
Gabe,
I normally don't reply to the board because I've never anything useful to add. This may be one of those times.
I have a 2005 XC70 and it was doing the same thing. I did the same thing you did - it looked like the mechanism worked just fine.
Out of frustration, I just shot some lubricant up into the latch - and I mean just up around everything with the door fully assembled. I just used the little plastic straw (I think it was WD-40), shot it around where I could get inside, and let the excess drain out and carefully wiped everything clean.
The lock works great. You probably already tried this, but sometimes I look over the really simple things.
RaymanSean
Year and Model: V70 XC, 2001
Post by RaymanSean »
I have done the same thing with locks on my BMWs and it helps. Good idea W! I would start with some penetrating fluids and them move to white lithium grease once you get it open.
chairexpert
Thanks Guys, I will give it a shot.
chairexpert
Okay guys, so I tryed the wd40 to no avail. Could it be a fuse? the windshield wiper is also not working. is there a connection? Help help help! Christmas is on the way and I can't get anything in my car. LOL!
Thanks
gabe
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
Check for broken wiring at the tailgate hinges.
