99 T6
the wires that power the washer fluid pump and level sensor seem to have been ripped apart.. i can solder them back together but its hard to understand which wires connect to what,the yellow wires seem to be intact, but there are 3 black wires that are ripped, i have vadis but it only shows the harness not the wire connections.
Would anyone please be able to take a pucture and post it here of the connections underneath the washer fluid bottle? im pretty desperate now as the car is not safe to drive without washer fluid available with the snow looming so i need your help ;-(
Washer fluid reservoir wires ripped
andrei3333
- Year and Model: 1999 S80 T6
1999 Volvo S80 T6 Bought @192KM...now @224KM and counting the high priced maintenance miles
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The black wires are all earth (ground) wires. The wiring diagram shows the earth lead from the washer motor goes to the same earthing point as the wires from the washer level sensor and the right side signal turn light. That would account for the three blacks.
With broken earth leads it doesn't really matter which is soldered to what, more so as they all go to the same earthing point.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
andrei3333
Fixed, thanks, i could not get under there comfortably so i paid someone else with a lift to do it, but all is fine now, i still had the turn signal working though, but the fuse for the washer pump blew and had to be replaced as well btw
- 36 Replies
- 21571 Views
Last post by StickyPocket
- 4179 Views
Last post by eyerollXC70
