C70 Door wont latch
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
dj5150
Year and Model: c70 2001
C70 Door wont latch
Post by dj5150 »
passenger side just bounces back, will latch only if you hold it against the body and hip check it. embarrassing with the chicks. Is the latch/lock mechanism adjustable?
VolvoTurbo850
Year and Model: 1994 850 (T5)
Post by VolvoTurbo850 »
not if the chick is between you and the car ;)
Yes it is adjustable, like the chick, you have to figure out if it is lose or parts broken inside.
I sometimes use a screwdriver shaft to push the mechanism in and out to see if it is catching or something has broken or gone out of alignment.
It could mean you have to replace the mechanism, but have a close look to see if you can find the issue.
Also check your hinge bolts on the door in case they are loose and causing the door to be misaligned.
The Fleet
2001 V70 (NA) 2.5
1999 C70 Conv. Turbo 2.3 HPT
1998 S70 Turbo (T5) SE
1994 850 Turbo (T5)
1980 Corvette (Corvolvo)
Previous Possessions: (4) 240's, (1) 740, (9) 850's, (5) 70 Series
Projects on the go: NONE... Yet!
dj5150
Post by dj5150 »
nice!
yes I will poke around in there again, the "thing" that rotates up and down inside the door what ever the hell you call it is much looser on the pas side than the drivers. so if the whole mechanism slides fore and aft I presume I can pull the door panel and move it?
BTW- THANK YOU to all the experts who so kindly have helped me here, money is tight and volvo mechanics charge a lot which I do not have a problem with but again.......bank account is hurtin!
VolvoTurbo850
you might not have to remove the door panel as there are two screws right there on the side.
The Fleet
2001 V70 (NA) 2.5
1994 850 Turbo (T5)
RaymanSean
Year and Model: V70 XC, 2001
Post by RaymanSean »
sounds like it needs some lube. Really, I would hose down the the part that rotates (towards the axle it pivots on) with some WD-40 and work it back and forth to see if it loosens up. It sounds like some gunk has built up over the years and it needs to be worked out. After the WD-40 I would go with some white lithium grease into the same area and then clean up all the over spray.
