Have slight leak from doing valve cover gasket on my 740 turbo. It's at the front. I didn't clean out the old silicone and apply new. I didn't/don't know how much silicone to use and where? It looks like there was some around the camshaft "humps" front and back. Do I need to let it dry before I put it back together? Can I put some on the gasket on both sides from front to back? Also, should I put the gasket on the head or the valve cover at first?
Thanks!!!!!
changing valve cover gaskets....again
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I think you are going to hear this a lot. You don't need to use silicone on these engines. As a matter of fact, I have never used silicone sealer on any European engine. I use non-hardening gasket sealer such as the aviation type.
1988 Volvo 760 Turbo Wagon
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
+1.
Bill.
On the head, otherwise it falls off the cover when you turn it over to put it on the head.Also, should I put the gasket on the head or the valve cover at first?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
OK this is what you do,first clean the valve cover good and then find a flat concrete floor and move the valve cover around a bit then look to see if there are high spots. These will be indicated by slight scratch marks, if the cover is badly warped a machine shop can fix it further. Go and buy a real Volvo valve cover gasket and coat one side of the gasket that meets the valve cover with either a Permatex Hi tack or better yet use "gaska-cinch" by Edelbrock on the cover itself. Let the parts dry for 10 min. and press them together carefully,this is contact cement and will allowthe two parts to bond together and form a neat seal. don't overtorque the 6mm bolts, you don't want this to look like too much mayo on a sandwich with sealer squishing out.
- 884 Views
Last post by hermechanic
- 13 Replies
- 12676 Views
Last post by SVO LOU
- 998 Views
Last post by 93Regina
- 879 Views
Last post by stephansvolvo
- 1256 Views
Last post by Clockboy
