ABS Problem Topic is solved
ABN
ABS Problem
Post by ABN »
Sometimes the ABS light gets on and sometime it does not. I put the codes on A3 and I got code 1 4 2 .
I do not have the codes list so I do notknow what could be the problem.
Any idea ??
Please your comments and help if it i spossible, thank you.
[email protected]
ABN
Post by ABN »
Could I receive any reply , help , or just a comment about a similar problem ?
What means code 1-4-2 ?
What spare parts do I have to buy to fix it ?
Thanks
[/b]
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
According to http://au.geocities.com/ozbrick850/comp ... volvo.html it means 'ECU faulty' which of course does not make sense with your problem. Are you sure it's a 1-4-2?
Also -> Amazon link
dosbricks
Been thanked: 2 times
Post by dosbricks »
ABS Socket (A3)
Code 142: Faulty brake pedal switch, open or short
floryed
Post by floryed »
Where is the brake pedal switch? Referring to 1-4-2
White850Turbo
Post by White850Turbo »
Brake pedal switch is a little electronic switch behind the brake pedal lever that creates an open circuit when the brake pedal is applied.
Here is a pic:
dias
Post by dias »
I have the same code but when the abs light comes on my indicator lights stop working!!! Any ideas on this? What relations are there between the ABS and indicator lights? In the wiring diagrams there is no relationship beytween them except some ground points which are in position and working perfect.
