V70 electric parking brake
This topic is in the MVS Volvo Repair Database » Timing Belt Intervals , Volvo PDF
meddyliol
Year and Model: 2008 V50 2.0d SE Lux
Post by meddyliol »
Hi, I have a 2008 V70 D5 SE Lux and have been reading on the Volvo Owners Club Forum about problems with the rear brake shoes disintegrating. Does anyone know anything about this apparent problem? How does the electric brake work? Are there separate shoes as well as discs or what? The car has done 55000 miles.
Thanks in anticipation
Brian :mrgreen:
2008 V50 2.0d SE Lux Powershift
ed7
Year and Model: V70XC 2005, 2001
Has thanked: 2 times
Post by ed7 »
Your car is a bit young to see the lining separation from the parking shoes. The parking shoes fit inside the hat of the rear discs. The lining typically falls off the shoe because of water saturation and rust and lack of inspection. It is not an apparent problem; you must find it before it finds you.
Ed
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
If you have the electric parking brake system it uses the brake pads against rotors and doe not have the drum parking brake system.
IF the EPB had an issue with shoe disintegration you should also have foot brake issues.
The EPB uses an electric motor to drive a fine thread screw that applies through caliper to backside of piston. The apply thread part floats so piston can move independent from EPB hardware. EPB is used on a number of cars now and has been problem free except when rusty calipers are thrown into the mix. Rusty calipers not having anything to do with the EPB hardware I might add, but due to salty roads in winter.
meddyliol
Post by meddyliol »
jimmy57 wrote:If you have the electric parking brake system it uses the brake pads against rotors and doe not have the drum parking brake system.
Thanks very much for your answer. It has put my mind at rest. I was SHOUTED at on the other forum because I said it works off disks only. Can I take it that it also works on the front as the manual states that, if it is used as a parking brake it only works on the rear. If used as an emergency brake whilst moving it operates on all four wheels until the car is almost stopped when it reverts to rear only.
I hope this makes sense
Brian :mrgreen:
San Diego Patrick
Year and Model: 2008 V70
Post by San Diego Patrick »
Along these lines...I was in the process of changing my pads and rotors on my 2008 V70 and when it came to pushing the piston back, in order to fit the new pads in....No Dice. I was told that there is a "computer release", that needed to be done by a dealer!? I called an independent repair place and they know nothing about it. Is there a special tool or computer that I need to release the piston so that I can get the new pads back in?
Locky2001V70
Year and Model: v70 P2 2001
Has thanked: 1 time
Post by Locky2001V70 »
I know that this is an old post, but Ive just had the message come up in our 08 XC70, regarding Parking Brake service required with the Brakes locked on. The parking assist service light is also on.
Luckily the car was at home and I have my '04 V70 to drive to Uni.
Just wondering if this is an expensive repair?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Wrong forum, 08 is P3.
Has thanked: 1609 times
Been thanked: 4065 times
Stand by for the shift.....three two one...
Screen Shot 2019-06-12 at 1.03.44 PM.png (416.15 KiB) Viewed 2914 times
