2003 XC70 - Fuel Door Will not Open
Marineboy007
- Year and Model: 2003 XC70
My fuel door will not open via the remote switch. I have dismantled the well area behind the fuel door. No direct access is evident. I cannot find a manuel release. Any suggestions?
JRL
- Year and Model: Several
- Been thanked: 16 times
Should be there.
Remove all the right inner panels, there should be a cable there.
Look far forward, almost to the rear door
Marineboy007
I will look for the cable first thing tomorrow and let you know. In advance Thank You!
2001VolvoXC70
- Year and Model: XC70 2001
The problem may be the relay, try switching it with another one of with the same part number. Its located in the rear drivers side panel opposite of where you are looking for the gas cap release.
They've done studies you know. 60% of the time I work, every time!
