249,000 miles
leaking oil bad at turbo and engine is building up pressure indicating bad rings...
burns oil to the extent i don't think it's good/healthy to drive it...
so, what to do?
I don't want to keep putting money into this car, got about $1600 in it so far over 6 months.
Should I try running some kerosene with the oil to "glaze" the cylinder walls?
Aside from that, what should I try to sell this thing for? It's in otherwise good condition, new fuel pump, good tires, good transmission.
90 turbo may be done, what to do?
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
Might be a moot point, but have you done a compression test? It may just be that the rings are coked/packed with carbon. You could try pulling the plugs and pouring some B12 chemtool or seafoam, down into the cylinders, letting it soak in for a good while to break the carbon down. This helped me with my S80, I had a major compression loss in a cylinder, did the seafoam down the plughole thing and it worked very well. Ive heard good things about that engine "restorer" stuff, but I think I'd start off by trying to decoke the rings.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
- 1054 Views
Last post by jmscdgn
- 583 Views
Last post by cn90
- 1234 Views
Last post by obayha
- 832 Views
Last post by Gubernaculum
- 815 Views
Last post by - Pete -
