Drivers door open
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Geespeak1
Year and Model: V70 2004
Drivers door open
Post by Geespeak1 »
Started my 2004 v70 and I had a note in info windo that drivers door was open. New so I thought that maybe I had gotten some moisture in the door switch and it (door) wasn't being seen as shut. Well I hadn't gotten vehicle wet in car wash.
Guess I'll need to take apart door or at least remove door interior panel to see what the deal is.
Someone must have had this experience happen to them did the switch go bad, get jammed, derailed etc.
does panel just pop off?
Am I missing something alse like loose front lugnut right side? Odd that it just popped up. When I pulled fuse to get the ringing to stop info window said srs airbag need urgent service or something to that efect. Had to re-insert fuse so I assume that a disonnect of battery will clear that code, hopefully.
Thanks,
Bill
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Is this a double post?
