2006 S40 Air Conditioner
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
hagen27
Year and Model: 2005
Post by hagen27 »
Happy Holidays Everyone!
I truly appreciate all you guys do to make this site so useful for people like me, who like to DIY. I know this may be an odd time to ask for some help with air conditioning but since I have some down time right now I wanted to address the issue that has been bugging me for some time. When I start the car and turn on the air it works fine for a little while, cool air is blowing out then all of a sudden the cool air stops and warm air replaces it. This was intermittent with the cool air starting up again then turning off. Is this just a freon issue with the conditioner (needs replacing or topped up?) or something more sinister with the unit itself? Any help is appreciated.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It could be low on freon. The only accurate way to check is with gauges to find out the low and high pressures. Have you noticed any icing on the pipes when the cold air stops?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
hagen27
Post by hagen27 »
Hi Bill,
Thanks for the response. Good point to look for icing on the pipes. That should give me a clue to low freon.
billofdurham
Usually when the pipes freeze up it is due to a restriction in the orifice tube caused by air and water getting into the system. It is not an indication of low freon. If the freon is low the compressor will cycle more often. Start the AC and watch the centre of the compressor. If it starts and stops after a few seconds the charge is probably low. However, as I said earlier, you need to have the system checked with the proper gauges.
Bill.
Previously:
