Hello All,
I am in the process of replacing the front passenger side control arm and cannot get the bushing bolt off. I sprayed everything with PB Blaster prior to starting and the nut for the bushing came off without a problem. The bolt on the other hand would not move. I tried using a cheater bar on it to see if it woould budge and it cracked the craftsman socket I was using. I switched to an impact socket and the bolt stripped. Is it supposed to be this hard to loosen? I tried to tap it out from the other side, but the bolt would not budge either. This bolt isn't threaded into the other side is it? Any assistance you guys can give me would be greatly appreciated.
Many Thanks,
Jay
Control Arm Replacement Help
reds70turbo
- Year and Model: 1998 Volvo S70 GLT
It is more than likely seized to the subframe area there. It sounds like you may need a little help from a torch. Heat that sucker up after soaking with PB. I would try to break the bolt loose by turning with a wrench or ratchet. With some heat I think either would break it free.
1998 S70 GLT - 183K - full of fun stuff and meticulously maintained!
yojaywuzup
- Year and Model: 850 1997
I put the torch and some PB Blaster to it, but once I brought in the 3lb hammer and the socket on an impact extension, it gave in fairly quickly. Thanks for the advice.
- 13348 Views
Last post by MarcM
- 2990 Views
Last post by 800artfreed
- 25 Replies
- 5242 Views
- 1154 Views
Last post by s_watts
- 4191 Views
Last post by Tonyx
